Ishodu
What high and low slopes are you using if you are running 48# Accel injectors?
Thanks
Thanks
I always wondered why the stock XJ2 had such a large slope for the stock injectors (27/72 or something). Everything I have read on slopes suggests numbers much more in line with what you guys are using, actual injector size x 1.15-1.25.
I don't even know if I am suppose to mention this or not ... BUT I will. I know I will open up a can of worms on this one ... this is a very recent development.
The injector slopes are WRONG in Caledit. BE has it right, thanks to Adam Marrer. Caledit labels the High Slope as the Low Slope, AND lables a just recently found setting used only for idle (Mass Air Flow adder idle setting) as the High Slope. The actual High Slope setting isn't there in Caledit. The reason we were able to tune with Caledit, is that in the Ford 2 slope stragety, the Low Slope becomes an "adder" once it passes the breakpoint. The crazy 72 injector setting is actually a miss calculated air flow setting.
