AC question?
MY SHO
Wayne NJ
I was looking for the low pressure switch to jump out to see if my compressor works i know im low on freon, but i want to see if the ac clutch engages at all...Where is the AC low pressure switch located? Thanks in advance...:thumb: Also i tried installing freon and it would not take any could there be a possible blockage in the line? or because the Compressor is not engaging to take the freon?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
on the dyer at the firewall (ATX) or just rear of the radiator on the lower left on the dryer (mtx) (I think). Sometimes you have to jump the switch to get them to take refrigerant.
93rev2sev
Hockeytown
A/C pressure switch on a automatic is right up against the firewall. It's under the sight shield on top of the coffee can lookin thingy
MY SHO
Wayne NJ
Im sorry its a 5spd stick so thats near the rad? where is it ? is it easy to get to the switch...?
93rev2sev
Hockeytown
You can reach your hand between the battery and the radiator...it's down about 10 inches...on top of THAT coffee can lookin thingy.
MY SHO
Wayne NJ
Well i tried jumping the low pressure switch and it turned on the compressor kicked in....I tried to put the freon in and it wouldnt take when i turned the valve open it went right the the danger zone of the gauge and would suck in the freon? Now what....lol...any suggestion would be great thanks...:)
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Well, the pressure is going to be high while it is sucking the gas in. It will go back to normal when the can is empty. R-12 or r-134a? Are you putting the freon in the high side or low side also?
projectSHO89
SHOless In St L
Yep, the gauge will read the can's pressure, not the system's, as long as the can's valve is open. Depending on the temp of the can, you might see pressure readings of anywhere from 50 to 90 psi from the can.
...assuming you didn't connect to the high side which can result in the can becoming an IED in your hand.
The can's own pressure should be enough to "make" the cycling switch. Many jumper the switch to get the process started.
Steve
itwonder
VA
Is is possible you connected the freon can to the high pressure side service valve instead of the low side valve?
