AC / Cooling problems
jspec23
Lowell, Ma
Ok, so my cooling fan is being manually controlled right now with a switch I put in. I ran power right to the harness. The fan never turned on, even with the def. and AC on. Now, my AC is not working either. I press the max AC button and I can't hear or feel the compressor kick in. Is this most likely a CCRM issue? It's real hot around here, this sucks!
SW SHO
Boss Man
Santa Fe, NM
Check your connections on the compressor and the accumulator. You may want to do a search here for a/c not cycling and such.
