Brian Smith
I installed my 96 brakes today along with moog cargo coils and monroe sensatracs up front. Everything went well, the whole process was smooth and without interruption, except when I tried to remove the abs sensors from the old knuckles. I destroyed both in the process. Can any gen 1 abs sensors be used to replace these? What is the correct gap between the teeth on the abs gear and the sensor tip? Does this gap matter? Anyone have some abs sensors they dont need anymore?
On another note, when I finished the job my drivers side alignment was really, really messed up. The top of the wheel was probably an inch farther left than the bottom, i guess this condition would be called toe in? It has me worried that conventional methods for alignment may not be possible up front. Otherwise the car rides much more smoothly now, though I have not put the new brakes through their paces as I plan to have them power bled first. Another new fan of the moog CC and sensatrac combo!
