My abs light is on now. Among many things I was doing to my 95 SHO the two things that could have caused the light are: 1. I damaged the rear abs sensor and sense have replaced it with a new one. 2. I accidently drained the reservoir when bleeding the brakes. The brake fluid had been top off at the appropriate level. I have put maybe 60 miles on the car hoping the light might magically go off to no avail. I have disconnected the battery. A local mechanic told me to remove the battery, connect the positive and negative wires and let set over night to reset the computer. I tried having it scanned at O'reilly's and Autozone but they did not have the correct scanner.
I have parked the car for winter, so I have some time to figure this out. Any ideas on possible problem or does anyone know of a chain type store that might have a scanner that can read the codes?
