ABS light, codes....
ericwick19
saginaw, MI
can anyone help...my abs light is on and the abs doesnt work, i checked the sensors and everything looks good, but when i put my snap-on scanner on it, it doesnt find any codes with the KOEO scan test....any help?
93nighthawk
Mitchell, SD
What year of Taurus is it? Did you pull codes off of the EEC or the ABS connection? To hazard a guess I would say one of the sensors that connect to the wheels is broke. They ride on a thing that looks like a gear right behind the disk. That tends to wear out also. Without any more info, I don't know what else it could be.
Eric
'93 Green 'NITHAWK' ATX
120K MI, Fish tank ligts, Sho Shop Y Pipe, Sho Shop SFC's, Removed Silencer, Sho Shop 60K, Replaced Motor Mounts, New EGR/PFE
'78 Green/White Bronco C6 AT
200K mi+ on body, 30Kmi on engine, 351M, 4brl Edelbrock carb, Edelbrock intake, duel exaust, lifted, rusted to **** but can go anywhere...
'95 Mercury Mystique ATX
110K mi, 2.0 I4, studs, Great parts getter for the other two vehicles.
40' x 40' heated garage to work on all 3 :D
9
94ShoOff
Guest
I would start simple and cheap, check the fuse. If it blows you will get the light and the abs will stop working.
