abs controller for 1999
firebat45
Edmonton
Is the slo controller the same as the sho abs controller? What else is compatible, if anything.
venom
Rowboat Design
Toledo, OH
The ABS module is SHO specific. It is not model year specific. Any Gen III SHO in the boneyard would have a compatible module for you.
whiteknight
canada
Does anybody know if the electronic modules can be swapped independently of the hydraulic pump unit?
Someone has said: "The pinouts are all the same for all four years of the SHO",
but in a later post I found the quote:
"Bosch Bar Code numbers on controllers are different."
The module in my '99 has fewer pins on the electronic module itself, the replacement part has a connector full, with none missing.
Are they interchangeable despite this?
Thanks
