I have been a member for a while and have found allot of useful information on here. I have a 1995 Taurus SHO Dk Grn, Auto, 158,000 miles. Things I have done all are basically maintenance items, crankshaft & camshaft position sensors, front and rear struts/springs nothing fancy.
I had an on and off problem with the ABS were a low speed the brakes would lock up on their own, say like when you are looking for a parking spot in a parking lot. So I pulled the main ABS fuse and that temporary solved that problem. Then about a year ago my right rear caliper would stick, and finally about 8 weeks ago it froze up!
I though ok no big deal replace both rear calipers and away I go right wrong! It turned into a huge mess rusty brake lines leaking, replacing rubber supply hoses and everything. With all that done now it’s time to bleed the brakes, let’s get the party started yeah right. What a nightmare it has been so in my frugal way I decided since I have been without ABS for over a year I didn’t need them. So I did some research into what might happen oh wait I forgot to do that and just cut the line and said the heck with it.
I have the brakes plumbed in a tradition front axle primary circuit and rear axle secondary circuit, so far it seems to be working I will keep all posted as winter approaches. And before you ask everything is bypassed I have lines going to the front and lines going to the back and nothing in between. I will see if I need to add a more traditional proportioning valve when the snow hits.
I could go into more detail if anyone wants, I drive the SHO everyday to work on the freeways and everything here in MI so it will be a good test.
