AACKK! Where can I find this bolt?!
DemonNeno
SHOCAGO Freak
Skokie, IL
To All
I'm in search for a Rod Shifter Linkage Stabilizer bar bolt. The one that bolts into the trans housing. It's a long bolt. I need it.. However, it's only offered with the Rod Shifter conversion kit, only. Nowhere else have I found the right size and grade bolt. Anyone have one or know of where I can get one?! Price isn't a problem, but time is!! TIA
Happy New Year!
Neno & The '91 Dark SHO
SHOCAGO Enthusiasts Club - http://www.shocago.com
137K Mi., Black on Black/Mocha Interior, '94 Mark VIII Rims, 225/50VR16 Comp TA VR, Rod Shifter Converted (Broken stabilizer bolt, still sitting in my trans housing!), SHO Nut Reinforced Motor mounts, Coneless, 3.2L larger crossover tube for intake installed (sure did make the intake LOUDER!), Delrin SFBs, Semi-loud exhaust system...
Ready To Install: Subframe Connectors and Intrax springs instead of Eibachs?
Coming Soon?Konis/Poly setup
DemonNeno
SHOCAGO Freak
Skokie, IL
Hey Fred
Well I tried boneyards.. All i bump into is Cable SHOs... hmmph.. And as far as automotive places, their largest bolts are a 125mm in length, but my main problem is I don't know the dimensions of the bolt since it snapped and went bye-bye! I'm still trying to figure out how the **** that bolt broke like that! I need a torque wrench *shrug*...
DougLee25
Hatboro
Went through the same problem last week when I converted mine to a rod shifter. Took me over 2 hours to find the bolt. I found mine at Pep Boys believe it or not. They never have what I need. There was only a few threads that caught on the trans, but it then began to squeeze the bushing and there was plenty to bite in the trans housing. Let me know if you can find one.
~Doug
DemonNeno
SHOCAGO Freak
Skokie, IL
What size was the bolt? If I find something, I'll let you know.
jthomas68
Area 51
I think it`s 12X1.5mm,i got a 4' rod of it,cut it to length,and used nuts on it.It`s been holding fine for quite a while now.If the hole started to strip the last few threads since the original bolt was loose,a bolt replacement will not stay tight.Get the threaded rod in and secure it with a nut,then slide on the shifter rod,then use 2 nuts tightened against each other with a small amount so slack for the shifter movement.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
