SuperHO
Mental Patient
Once you get the tire off and the wheel well liners out of the way, here's a breakdown for ease of removal and replacement from a first-time point of view.
Wrangle your arm in from the top and remove the top bolt first. You might be lucky and be able to use a ratchet...none of mine would fit so I had to use a regular wrench.
Now pop the belt loose and remove the two 15mm bolts on the bottom.
Here's where it gets fun.
At this point, you should've already knocked the outer tie rod loose. You need to rotate the alternator so the pulley is facing down and the bottom of the alternator is facing the hole. Now turn hub to the right and move the sway bar end link and with a little wiggling, it'll come out easily. Installation is exactly reversed.
