POSHO
1) My Gates timing belt doesn't have all the white guidelines on it like I'm seeing in all the pictures...is this normal?
2) where can I find a replacement bolt for the 19mm harmonic balancer/crank bolt?
3) what bolts can be reused when swapping from 89-93 to 94-95 front steering knuckles? I will be replacing the hub nuts anyways, but will everything else fit back up?
T.I.A.
T.I.A.
