A/C question with pics
morebhp
Atlanta, GA
These accumulator assemblies don't come with a cycling switch. I'm ignorant of this stuff so I must ask before getting into the middle of this project.
There is a fitting on the canister seen in this pick. Is this where a cycling switch like the one pictured below is installed? Does it screw on? Please explain. Thanks!
Visteon drier/accumulator
Cycling switch
Mr Anonymous
Tire Wall
Cycling switch
Yep, it's just a little schrader valve on the tank, and the switch just screws right on.
SHOtimer
#2910
Santa Clarita, Ca
It does just screw right on, but it has an O-ring that seals it. Make sure to install a new one with a little bit of oil to **** it.
Doug
morebhp
Atlanta, GA
Doug,
This o-ring.... does it come with the switch or is it separate? If separate, will it come with an o-ring "kit"?
Mr Anonymous
Tire Wall
The accum/hose assy will probably include one as will a new switch. The one with the hose assy will probably be in a little baggie inside the big bag the thing comes in and can easily be missed.
Are you going to get your A/C working by the end of the summer? :evilgrin: I did two V6 complete A/C systems (sans evaps) last week while we were talking about this, and I've got two V8 cars to do in the next week or so.
morebhp
Atlanta, GA
Well, that's the plan. I think I have all the parts I need now. Some are still in the shipping process. See my other thread.
Sounds like you are a pro at this. I've not messed with those couplings yet. I need to get a tool to disconnect them... and I assume another tool to reconnect the new parts. Any suggestions? Is it hard to do?
I hope to do this right the first time and not have any leaks.
93rev2sev
Hockeytown
The little toolkit for AC/fuel line fittings is less than $10 bucks
You need the kit to remove stuff, but the new hoses just snap together. You CAN use the tool for easier "snaptogether-abilityness" but it's not needed.
morebhp
Atlanta, GA
Okay, although admittedly fairly mechanically inclined, I'm having trouble visually figuring out those clips I see on the A/C line joints. I guess once I get the tool in there and start working with it, I'll figure it out. It's just new to me.
morebhp
Atlanta, GA
The o-ring for the cycling switch... does it go at the base of the schrader valve on the accumulator/drier or does it go deep inside the threaded end of the switch and seal at the top of the schrader valve?? Anyone know?
