a/c problems
91_SHOster
Fresno,CA
well it's starting to get hot and my a/c isnt working in my 91 at all, but before i begin to spend the money, I'll see what you guys think...
I turn the a/c on, not cold what so ever, then my idle drops to about 600rpms and then surges back and forth to normal idle. I also occasionaly get some belt squeaks..
any help would be appreciated
SASHO91
Zoom Zoom
San Antonio,TX
Have you set the idle yet?
AS for the a/c not being cold...
Anyway you can run it by an A/C shop? i would need readings to tell you what the problem is. With out pressure readings, i cant really tell you anything... however, being that it is a 91, and it is on r-12 (assuming) it probably hasnt been serviced. Which right off the bat, would lead me to believe that it is low on Frion. However, i do need the readings to confirm this.
also, is the a/c compressor kicking on and cycling?
tominos
oregon
pop the hood with the engine on and see if the ac compressor runs with ac on.
91_SHOster
Fresno,CA
yeah the compressor seems to cycle on and off, and the idle drops and raises when it comes on.
