On my 95 ATX my A/C is blowing cold air - sometimes. Everything will be working fine and then the cold air gradually becomes warmer. I have read the posts about the blend door problem and was hoping that was it but I do not get immediate hot air after I hear a noise. I ran the diagnostic test and at the end the entire display lit every light possible. I assume this means the 888 message and that doesn't indicate a problem. I did not get a code 6 which is what I expected.
It sounds to me like the compressor stops working after awhile and that is why the air gradually gets warm. BTW the air blowing in never gets hotter than outside ambient air. Has anyone had problems with an intermittent compressor? Or know how to determine if I'm headed in the right direction? Right now windows down are working but that won't last long in an Oklahoma summer!
