Marccus
I installed a new Ford factory compressor, accumulator, compressor suction piping and condenser discharge piping.
I had an A/C shop vacuum the system and charge it.
Everything worked fine for about a month. But now the clutch won't kick in. I'm thinking there is a leak.
I have a Mastercool manifold gauge kit with leak detector, glasses, and UV light.
But I'm on a trip right now and will be traveling through Death Valley (110F during the day) and White Sands (as high as 120F).
So I'd like to use the A/C before I can trouble shoot it.
My question is will oil leak out with the refrigerant? If not, I don't want to buy those refrigerant cans at Pep Boys etc., because they all contain oil. Too much oil will increase the cooling temperature of the refrigerant/oil mix.
I'd have to buy just a can of R134a refrigerant and I guess I'd have to find a "regular" auto parts store.
If oil does leak out, I guess I should buy the refrigerant cans with oil in them.
Can anyone suggest which type of leak is most likely to occur refrigerant only, refrigerant/oil?
Thanks.
Can anyone suggest which type of leak is most likely to occur refrigerant only, refrigerant/oil?Thanks.
