DHMag
Free At Last
after 3000 miles of driving in 100 degree weather without A/C, ive decided to bite the bullet and redo the A/C system.
when i first got the car, the A/C didnt work. i retrofitted it the cheap way. it worked, but not very well. 2 weeks later, the compressor grenaded.
a year later, i installed a used compressor and charged the system without sucking it down. it worked like before. on a Fordbastard run, the clutch caught fire. removed clutch hub and installed bypass belt. havent messed with it since.
i am unsure if the compressor is still good or not. so would it be alright for an individual like myself to disassemble the compressor and successfully rebuild it ?
the main reason i want to disassemble it is to remove the remnants left in the system from the first compressor grenade. i disassembled that compressor and found the piston bearings wedged against the swash plate, gouging the swash plate. so i know there is trash in the system.
does anyone have any tips or tricks on overhauling a stock compressor for better efficiency or making it capable of higher RPMs ?
and one last question, what kind and how much oil do i add to a dry compressor ?
sorry for being lengthy and jumpy.
. as it looks, the 3 o-rings used for the body halves and ends are identical. so i have 6 of em.
