dstig1
Seems like my AC clutch is slipping a bit (a bigger issue when it is really hot or in stop&go traffic). I've already removed a shim a while back, so I figure since I'm going to have the whole front of the engine apart for water pump I should replace the AC clutch at the same time.
Which parts are needed? Looking over Checker Auto parts selection there is a Hub you can get or a whole clutch assy. The whole assy is $130 or so and the hub is only $35ish. I'm wondering if the hub is the only wear part or if you need the whole assy. Any clues?
I also want to make sure I get the right one since I know the SHO compressor is not the same as SLO. Is the 10P15F compressor the correct one? I don't have the manual handy...
Thanks
Thanks
