JRA2000TL
The Complainer
I need to do this on my 95 and have done a little research. Now that I was able to get the system fully charged, the a/c comes on upon a cold start up and works for 15 minutes or so, then goes warm. The clutch will not re-engage unless I whack it with a broom handle, then it engages only for a short period of time and cools until it quits again.
According to SHOtimes, I remove the battery and I can check the gap from there. Dumb question....how do I do that? Use the same feeler gauge I bought for doing my upper 60k?
As for removing it, the directions seem pretty straight-forward in using something to hold the clutch still, remove bolts holding it on, remove clutch and the washers/shims fall out. Re-assembly is the reverse procedure.
Just not sure how to check the actual gap and determine which one of the 2 washers/shims I need to remove.
snap ring out.
