Mullet,
Remove the nut or bolt that holds the clutch face onto the compressor crankshaft. The face needs to be "pulled" off of the shaft. If you do not have the puller for this, you can use two wood shims and drive them between the clutch face and the pulley.
The pulley is held to the compressor with a snap ring and removed with a pair of "snap ring pliers".
The snap ring is beveled on one side, and the beveled side should face toward you when installed correctly. The pulley may need to be "tapped" on to free it from the compressor, but it is not on with a "press fit".
You may need to remove a few things to get at the snap ring, such as the fender liner and front engine damper. It also helps to remove the compressor mounting bolt so you can angle the compressor to get at the snap ring. You do not have to disconnect any A/C hoses.
Hope this helps, rangerj
