I have been chasing the gremlin for a few weeks, I'm driving and all of the sudden I drop power the engine runs rough, then if I drive for a time it kicks back on.
It will also run bad when I shut it down and run fine later when I crank it up or run the same, last week I had it stall on me and would not start for a time, so I decided to change the cam sensor and crank sensor and a few other problems I had, got all that done and 300 miles later I get the loss of a cylinder, also I notice the tach reads a slower rpm when this condition happens.
When this happens I notice that I pull the spark plug wire at the coil and no spark at all, the others work, I also swapped coils,
I wonder what it could beanyone can chime in? :swing:
