97 V8 SHO engine-to-body resonating/vibration
Debo250
Texas
I can both hear and feel a resonating beginning around 60 - 65 mph and goes away @ speeds above 70. Primarily felt in front passenger floor near firewall. Had cupped tires trued and balanced but didn't go away. Shop said rear motor mt broken and replaced (Ford said OEM part discontinued) with aftermarket - still didn't go away. Mechanic said "live with it" but it's too annoying in an otherwise perfect running car. Any ideas?
Mr Anonymous
Tire Wall
Also could be a CV joint or wheel bearing, but even a perfectly balanced tire that's cupped will still not ride right (something like a torn belt in the tire could also have caused the cupping and contribute to vibration).
Have you tried rotating tires?
JrodSVT
Wheaton, Illinois
although it was probably a severe case but I had a factory Conti break a belt and it had vibration at all speeds. I would look at a CV joint or wheel bearing.
If a mechanic told you to live with it then he is not a mechanic but a parts changer. Everything can be fixed one way or another as long as the correct steps are taken to diagnose the problem. Try a new mechanic or another dealership.
Debo250
Texas
Duly noted. Thanks for your reply.
Debo250
Texas
Couldn't agree more that anything can be fixed with the right investigation being conducted. I'll make my case and try another shop if necessary. Thanks!
Red Devil
Boston
:stupid: I'd look to the tires first, including the pressures you're running.
