Hi everyone. My '97 sputters and I'm out of ideas. I hope someone can help. Ok, here's what happened. I drove 70 miles down the interstate. As I slowed down at the bottom of the ramp the car started idling rough like it was overheating. So I stopped down the street where I work and looked at the engine and it was hot and coolant level was fine. Checked both radiator hoses and both were equally hot. Leaving me to think that the thermostat didn't stick shut.
I had to go back to work. I let the car cool down until the next day hoping that the erratic idle from running hot would be gone and would start up and run fine.
It cranked like it didn't want to start. After It started, it wanted to die out and was sputtering the same as when I parked it hot. I checked the codes with my OBDII scanner and no codes came up when the engine was off. However, With the engine running and doing a KOER test, I came up with 3 codes (IAC issue, temp sensor out of test range, and test incomplete). So I started by replacing my IAC with a new one, then everything else trying to fix the problem such as TPS, MAF, Intake air temp sensor, both coolant sensors. All new sensors but still have the same 3 KOER codes.
One thing to note is that the car does not hessitate like a fuel issue when I rev it up. But smells like gas really bad when it is running. I was thinking a misfire but don't have any misfire codes or Coil Over Plug codes. I also checked the IAC passage and it is clean.
I am out of ideas. The only thing I can think of that is left is the PCM. After that, I may have to take it to a dealership and I totally want to avoid them at all costs.
Please let me know if anyone has any ideas. I really really appreciate your guys help. Thank you in advance.
Jason
Jason
