Groove44
Ok, so I am selling my car locally and I couple came out to look at it today only to come to a car that won't start. It won't even crank over. Everything power works, radio, fans, moon roof, all of the fob functions including lock, unlock, trunk pop and panic alarm. The antenae goes up and down, the interior and exterior lights go on and off, everything I checked works fine... until you try to turn the key over. The only clue I have is a very faint clicking noise when I turn it over, it didn't sound loud enough to be the starter, but I decided to look anyway, I had my little sister turn the ignition while I looked and it won't even kick out, move make noise or anything... it sounds like to me its coming from the under-hood fuse box/airbox/TB area but no matter how many times I have her turn it over I can't pinpoint it. I tried cleaning the battery terminals, checking the terminal wires, swapped all IGN/STARTER/JCT/ECC fuses and relays with known good ones to no avail. My sister did say sometimes while she tries to turn it over the doors would lock and then unlock and I saw them do it.. anyone have any insight to a similar problem or have the exact circumstances? Thanks
