96 sho BAD VIBRATION ?
allan greyling
atlanta georgia
ok i have a 96 sho with 18300 miles on it i bought it about 8 months ago for $750 someone had really abused it so i am trying to bring it back. it runs fine and is fast as ****. but the proble is i recently took it to ford performance here in ga and spent $2300 to have the cams welded a 100k mile service ball joints and sway bar links and also sct tunning done on it.(thought this was kind of high?) anyway i will be driving down the road at a constant speed and the car will get a real bad shake or vibration hard to discribe it is not from the suspension it feels like it is from the engine. it almost feels like it is surging. if i either accelerate of decelerate it goes away. some days are better than others but it is very annoying. had the shop look at it they said it would go away with the service they performed it has not. please anyone some help??
Mr Anonymous
Tire Wall
Check the forward mounting bolts/nuts on both a-arms. I've seen the symptoms you describe when one of those bolts has worked loose.
ShadetreeSHOguy
Postwhore
Dallas, Ga
Just gonna butt in for a sec and say welcome to the board:wave: Seems that we've had a wave of Ga new people join the board, Welcome:biggrin:
midnightauto
THE CHOP SHOP
Michigan
I just had one in the garage for a similar vibration it turned out to be a axle. it would vibrate under load and would seem to go away under coast or low power.
redSHO96
SHO Owner
Wappingers Falls/Utica NY
i know this isnt really experience with an SHO here, but my Fiero had that same kind of problem and it turned out to be one of the CV axles as mentioned above. I replaced that and it was fine, not a big job or overly expensive really.
allan greyling
atlanta georgia
i see thank you i did not get a chance to look at it today was working on my other project 92 alfa romeo 164 starter went out ( what a pain in the ass ) i will do a ford starter any day took me almost all day. thanks for the insight i will try to check out tomorrow.
poffffd
