i have a 95 sho 3.2l the car starts up in the morning,sometimes it runs fine then sometimes it runs and then cuts out.sometimes it drives fine and sometimes it drives and then cuts out.i have to let it sit for a while before it starts back up.from reviewing the forum i decided to change the crank sensor.before changing the crank sensor i could always hear the fuel pump primed with the ignition turned.i replaced the crank sensor following all procedures and tried to start the car and no start.when turning the ignition i noticed that the fuel pump was no longer working.i checked the wires going to the inertia switch and i got no power.i also tried to run the self diagnostics test and it wouldnt work.the fan wouldnt start during the test either.all other power is working,the car cranks fine but wont start.i backprobed and ran a test light to the crank and cam sensors,the ignition module,and the coil and i got no power.is it the relay box above the radiator or what?i also checked all fuses.
