95' ATX temp sensor and sender location
Jan Fiuczek
Lodz, Poland
Hello, could you please tell me where the temperature sensor and sender are located?
There are so many hoses, plugs and wires under the hood that I couldn't find those yesterday (it was dark, so...)
I want to place an order for the new ones and have to check their measurements first.
Thanks
BaySHO Performance
SF South Bay
Temp Sender for the gauge is behind the coil pack with a single wire coming off it. ECT Sender: two housings at the back of the motor. The front housing contains the thermostat. The rear housing is joined to the front housing by a short, wide rubber hose. The ECT sender is in the rear housing.
NoSlo
SHO Owner
Portland, OR
Here's a pic of most of the cooling hoses and parts. This diagram is just short of actually having the electrical sensors noted:
NumOnAj
The ECU's temperature sender is screwed into water outlet #1, facing towards the driver firewall corner, with very little slack in the wiring harness.
I had to replace the yellow one once...
