95 atx sho problem
thorpie6969
Ma.
Well alright i have a 95 sho atx and it has a weird buzz noise is coming from the back of my engine down blow i check the temp senor thats in check engine is not on so i have know idea what thats all about. Thats one problem the other is when my car goes to shift 1 to 2 its slams into gear almost like a neatrual drop it and i think it skips a rpm , had my transmission checked out they said it was fine, i thinks it one of my sensor. Does any one know about these problems.
Thanks Nick
MorpheusGPR
Ford TRIO
Indianapolis, IN
I have been getting some noise to since I got my car back together. I was wandering about the temp sensor since I cut the front of the air box to let more air in...
Wish I had the answer but I will be watching close.
ohfosho
ontario SHOwner
ontario, canada
i had to have my VSS (vehicle speed sensor) replaced this past fall...it popped a code, and my car was shifting like a retard. hard shifts, mainly 1-2...it was holding gears to about 4000 then dropping hard into the next. also downshifting when not required/requested.
thorpie6969
Ma.
Yea thats what it does holdes the gear then slams. Do know where the speed sensor is located and how much does it go for.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
I just did mine on my 94 and its a PITA. VSS is less that $20 from a parts store. It is located on top of the tranny on the passanger side and is held be a 10 mm bolt if I remember it right. Basically follow the speedo cable until you hit it.
ohfosho
ontario SHOwner
ontario, canada
yeah i couldent even find it so i had my mech do that and the O2 sensors...he said that he pulled off a cover that the VSS is attached too, and that was a lil easier. try to take some pics when you do yours, it could help many people!
thorpie6969
Ma.
Well i never replaced my vss because my mech said i didnt need to and if it was gone the speedo wouldn't work but anyways this is now whats happen ever time i start my car it idles a little weird it goes 1000rpm to 750rpm and just keeps kinda boucing and then when i put it drive and start going it doesnt really wanna go, it seem like its not getting enough gas and it still slames 1st to 2 gear. so i dont know i think i going to just rebuild the tranny. so any idea would be great at this point.
ohfosho
ontario SHOwner
ontario, canada
well its up to you, take an hour or 2 and about $50 to replace the sensor, see if that solves the problem...or go ahead and put a new $2000 or so tranny in.
check your codes, if your VSS has acted up since the last time your battary was unplugged, then it'll show a code 452 (another forum member is having the same issues in another thread right now, and i had my VSS switched a few months back, solving all my ATX woes)
p.s. where did you go that they checked your tranny?
thorpie6969
Ma.
aamco, but i checked my fluid and its clean no burning or anything its pretty weird.
thorpie6969
Ma.
yea i thought the same thing cause its not right, and i was wondering if i manual shift in the atx sho would that mess the computer up cause when i do the car way better and shifts better.
tominos
oregon
yeah i think he's talking about me. the car is shifting weird and cruise sometimes doesn't work. also had a code 452 which is vss so that's gonna be changed soon.
LeddZepp8687
The Keg Rider
Naperville, IL
VSS FTW, Mine went out also, I replaced it and did a trans flush and it shifts butter smoothe now. If you are good with your hand like I am then it should take you about 2-3 hours. Good luck!
Ohh yea and BTW, mine NEVER threw a code, onmly code I ever got was a TPS code. As a matter of fact thats the LAST code ive seen in over 4 months, everytime I check the codes for kicks, it always spits out and ALL OK code.
SeanMc
NoMoSHO
Heh, the only code I ever get is a 225 (knock sensor). No CEL tho. Sometimes mine will hold and then shift when under load, or just shift slowly. It's only occasional tho.
