95 ATX engine mounts
Yes. The front mount took about 2 hours with the draining of the radiator to get to the upper bolts and make an easier path for removal out the fenderwell. The lower radiator hose that was found to be near its end was also replaced. The rear mount is a little easier, but you still may need to loosen the exhaust system to allow the engine to rise enough (for the front mount too). Use a thick piece of wood to spread the load from the jack under the engine. Place the load only near the edges of the oil pan and never in the middle.
