95 ATX - Drives in Neutral
SoCal
Bill
CA
Driving to work today, tranny suddenly got real rough.
No problems prior.
It has about 50K on a full rebuild.
In drive, reverse, and park, it struggles driving forward. It feels as if both reverse and drive are partially engaged at the same time and fighting each other.
In neutral, I was able to drive 10 miles home no problem.
Shift linkage is working properly, moving lever on top of transmission.
Fluid is full, clean, and does not smell burnt.
Throws codes: 519, 551, 412, 639, 213
Why would it drive OK in neutral?
Could it be something external, or am I looking at dropping the transmission for another expensive rebuild....
zoomlater
Seattle, WA
Do a search for MLPS on this forum. Sounds like the switch is no longer aligned or may be bad
SoCal
Bill
CA
Thanks.
MLPS looks like an easy install, and not too expensive.
