94 SHO MTX problem!
Bizzy
If the water pump is leaking then it would be highly advisable to replace both the pump and the sensor at the same time. If you only replace the sensor you're going to end up in the same boat that you're in now several months down the road.
93rev2sev
Hockeytown
Agreed.
I replaced Crank Sensor on my silver one when I got the car...I knew the waterpump was IFFY but I left it.
Since February, I have had no problems with the new sensor being dripped on.
Edit: no bashing me for leaving the WP....the motor will be replaced with a 3.2..........Um.....soon?
Bizzy
Nothing to bash you about Tom. If it's only iffy, or even only dripping every now and again I don't see any problem with just leaving it be. If it's actively leaking onto the sensor though, it would be stupid to replace the sensor without replacing the pump as well.
People need to understand that sensors get wet to a certain extent. It's in the engine bay. What do you think happens when you drive in the rain after all. :)
Granted, the timing covers are there to help protect the sensors from getting as wet, but I've known of quite a few people who have gone without those covers for years and had zero problem with the sensor itself. My oldest son's car is without them and has been since the crank cancer was repaired on his last year and there's not even a slight indication of issues from the crank sensor getting wet.
Water from the water pump is different though since it's dripping from above and it's got (or should have) coolant in it. Anybody ever dip their finger into coolant? Ever felt how it's greasy feeling?
When the water pump is leaking badly the ingredients from the coolant is what I think causes the damage to the sensor. I think it coats the sensor and causes or contributes the sensor's early demise. I'm not sure if it corrodes the sensor or maybe shorts it out, I've never cared to inspect one that closely before. It's a pretty simple hall effect sensor.
All of the above is only my opinion and I'm certainly no expert in the field. I'm sure that I will be promptly corrected if I'm wrong. :)
kartmonkey9
Grand Rapids
replaced the crank sensor....doesnt run any better...rpms still jump...could the sensor be shimmed incorrectly??
SHOracer14
Me-0 Diffs-6
Toledo, OH
Why the Vehicle Speed Sensor? You can run fine without it.
I dsagree that no VSS will not cause problems. On my old 91' plus I had a VSS that got very tied up (could barely turn it by hand) and it would cause the car to buck and stall when coming to a stop. However I do agree that the problem at hand sounds like a crank sensor considering the tach is being affected.
SHOracer14
Me-0 Diffs-6
Toledo, OH
Check your fuel pressure after cycling the pump a few times and check how quickly it bleeds off. Also check your pressure while running. It wouldn't be a bad idea to swap PCM's woth a known good unit. For ***** an giggles I would try to replace the VSS anyways... it's only a $15 IIRC.
chrism3784
West Palm Beach, Florida
Mine did the same thing. It was the DIS. I'm not saying its that, but its a good possibility. Its an easy obtainable part at the junkyard that nicely fits into a pocket.
SHOracer14
Me-0 Diffs-6
Toledo, OH
This is a good possibilty if the DIS is not getting a good ground as it is a self grounding unit. Also make sure it is not rubbing up against that torque limiter... I've seen that happen numerous times. Rarel does it seem the unit itself goes bad but it is worth a shot.
