94 ATX Transmission Code?
bump_26
Central Ohio
I got the following code: 522 PNP (park neutral position) MLP sensor out of range in park
Is this an easy fix?
Yes it is the fan shaped switch on top of the tranny under the TB that has the shift cable attached. Be sure to follow directions and have the car in neutral when you change it.
