93 vrs 94\95 brakes?
Porod
Green Bay, WI 54301
Besides the discs being different sizes, what other difference is there? It it just the caliper mounting bracket that is different, or is the caliper different. I have about half of the stuff for the newer brakes, and just wanted to know what I would need to change it.
93redATX
SHOForum O.G.
WI
Yeah, you're going to need knuckles from a '94/'95 Taurus (SHO or SLO - SLO with ABS)(alternatively, you can use knuckles from a Continental or Sable, with Sable having same limitations as Taurus, Continentals all had ABS if I'm not mistaken). If you happen to find a '95 Continental in a boneyard, you can take all of the hardware from that car, as the '95 Conti brakes are the same as a '96 upgrade. Otherwise, get the knuckles, then hit up a parts store for the brackets, calipers, rotors, and pads. I believe NAPA sells the calipers and brackets for fairly cheap :shrug:
Excellent time for stainless lines, if you haven't gotten them on your car yet :thumb:
SHO Type U
The '93 do not have caliper brackets. Its a once piece caliper setup, that bolts onto the knuckle.
