93 to 94 ATX Engine Harness
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
Swapping 94 ATX drivetrain into 93 ATX shell.
Is the engine harness different from 94 to 93. Will I need to swap harnesses or will the 94 work with the 93 body harness?
bubba
ATX Connoisseur
Fort Wayne, Indiana
Yeah as far as I know, you have to use the 93. I could be wrong, however I'm leaning to the 94 has a couple of different connectors on it.
the engine harnesses may be the same, but the front body harnesses are definitely different. I would plan to swap the engine harness and use the 93 parts.
