General Geoff
battery is fairly new and very strong, also tried to jump it, still nothing. Checked for continuity between the starter solenoid and positive terminal on the battery and it checked out. Turning the key to start causes a relay next to the ABS controller to click, but otherwise no noises. Fuel pump primes as normal when key is turned to on position.
So my first thought is the starter itself or the solenoid is dead. The car has recently given me some trouble in cranking (cranking extremely slowly, just barely turning over), but then it would crank over nice & strong as if nothing was wrong. I had considered the possibility that my starter was going because of this behavior. I'm in North Carolina for the holiday and I'm leaving next Monday, so I'm hoping that the starter is all that's wrong so I can get the car going and get back to PA when the time comes.
Any other suggestions as to what to check? I already pulled the old starter and it's sitting in a box in the garage right now. Any ways to bench test it with a 12v power supply? how much wattage do I need to make it spin up? Is it normal for the insides of a starter to rattle when shaking it? Mine does.
