pitaSHO
Why do I do this to myself?
If you're looking for a very nice looking black/black 93 MTX, this is it. This is almost the stripper version; no moon roof, no keyless entry, no power passenger seat. It does have full leather, which is probably an 8/10. I have had this car for two years now and have been very happy with it (once I fixed everything and started driving it). I've been paring down my collection over the last year or so and this is the next one for sale. I had this car on the market a year ago, but I wasn't very confident in it's reliability so I took it off the market until I fixed it. Since I fixed it I've put 12k miles on it with no problems.
Pro's
Good paint - no rust (less than the usual wear and tear for a car of this mileage)
Great interior - no rips, tears, or smells (driver's seat is not ripped)
Good tires - almost new tires on almost mint slicers (THE BLACK TD PR2's ARE NOT FOR SALE WITH THE CAR)
Steering wheel is not torn or worn out - in great shape
AC blows COLD
Rear defroster works
Clutch is in good shape
Maintenance
Fully 60k'd
*water pump - $70
*crank sensor - $65
*timing belt - $30
*Ford front crank seal - $15
*rod bearings - $75
*Autolite platinum plugs - $26
*Valve cover gaskets - $75
*Three Ford cam seals - $10 ea
*Shim adjustment
*T-stat - $25
*Upper and lower radiator hoses - $40
*Oil pressure sender - $7
*Coolant temp sender - $7
*New battery - $95
*New belts - $40
TOTAL IN MAINTENANCE - $600
Mods
PnP intake runners - $190
BBB's - $200
K&N air filter - $40
SHOSource front and rear reinforced motor mounts - $260
SHOSource stainless steel catback exhaust with Magnaflow mufflers and tips - $800
SHOSource stainless steel catless equal length Y-pipe - $250
Stainless steel brake lines all the way around - $100
Super Blue brake fluid - $10
Tokico struts - $600
Eibach springs - $225
26mm rear sway bar
TPR in the rear only
Hard button EATC
TOTAL PRICE OF MODS - $2,675
Cons
*211k miles
*The rear package tray and center console are squeaky.
*The steering is kinda touchy.
*The engine needs a rear cam chain tensioner.
*The wiper motor doesn't work on HIGH. (will replace before sale)
*It seems to burn through a quart of oil every thousand miles or so. I think it's the valve stem seals. I've replaced just about every other gasket on the car. I've never left a pool of oil anywhere after the work was done which is why i think it's burning it, and most cars I've seen with over 200k or 15 years need the valve stem seals. (depending on what price I get for the car we may be able to work something out to have this done before the sale)
*The front strut bearings squeak.
*The decel button on the cruise doesn't work, but the rest of them do.
If you have any questions, please let me know. The car is currently my daily driver, and I drive 90 miles a day to and from work, so the mileage will go up until it sells.
Asking price is $2300
Thanks for looking.
Chris K.
Pro's
AC blows COLD
Maintenance
Fully 60k'd
*water pump - $70
*crank sensor - $65
*timing belt - $30
*rod bearings - $75
*Shim adjustment
*T-stat - $25
*New battery - $95
*New belts - $40
Mods
BBB's - $200
26mm rear sway bar
Hard button EATC
Cons
*211k miles
Thanks for looking.
Chris K.
