93 ATX Cooling Fans
kevinhill28
Arlington, TX
I have a 1993 SHO ATX and I would like to know which of the 2 cooling fans is the primary cooling fan and which one is the A/C cooling fan. I suspect my fans stopped working as I am overheating now. New CCRM Installed, New Cooling Switch and Temp gauge installed. Also cooling fan harness has been repaired due to bad connection and wiring. Also the impossible to find cooling fan resistor which mounts to the fan assembly is new. Purchased the last one in stock last year. I just want to test my fans one last time before replacing the motor but can't remember which fan is the primary fan and nowhere on Alldata does it list that info.
the way the Ford dual-motor fans work is they are either both on, or both off. They run low speed or high speed, but they both run together.
