Well it's been a productive weekend. I finished the valve adjustment, added the canister purge valve (thanks Maurice), replaced my BAP sensor for Rbruso's, and closed the circuit on the PSP switch.
Decided it was time for Test run #4. I didn't do a video since it sounds the same as test run #3. More later.
The good:
The not so good:
I need to figure what direction to take next with the valves. Either there are valve seats that are loose, bent valves, possibly worn springs, or something else - but I need to figure out what's behind this.
Also need to look into the engine vibration. Maybe its just me. Glad to entertain thoughts or ideas on these.
The good:
- No code 52/519 using either B9B1 or X2J
- No code 85/565 using B9B1 or X2J
- Found bad BAP connector socket - wasn't making contact.
- Tested Manifold pressure at FP Regulator hose
- 17.5 in Hg at 1000rpm
- 18.5 in Hg at 2000rpm
- 19 in Hg at 3000rpm
The not so good:
- Still getting BAP code 22/126 for B9B1 or X2J
- Vref test shows 5.12v
- Map/BP test 1.33 for my BAP, 2.62 for Rbruso's BAP. Both apparently out of range 1.39 - 1.66v. For our altitude it should be around 1.4v
- Check impedence on all three lines to PCM pins: Vref = 2.2ohms, Map Sig = 2.4ohms, Signal Rtn = 8ohms
- Still have valve noise on Cyl #3 intake at low rpm - same as on this video. I also adjusted both of these to .18mm & .15mm.
- The motor doesn't run smooth - in a mechanical way. I'm noticing vibration (high frequency, not violent shaking) with rpm increase. It just doesn't have that smooth hhmm to it. Keep in mind this is a used motor and I only worked on the top end.
