914-SHO Need 3.2 Cyl/Piston Specs?
3d914
OK, just started doing some measurements on the pistons and cylinders and realized the specs I have from the Ford Engine Operations manual are for the SHO 3.0L - I need them for the 3.2L.
Here's what I have for the 3.0 & looking for something similar for 3.2
image.php
image.php
TIA
for 3.2
bore 92.0mm (3.6220")
piston: 91.960-91.990mm
piston to bore clearance: .030-.050mm
service limit .080mm max
ring groove width
top 1.23-1.25mm
2nd 1.51-1.53mm
oil 2.81-2.83mm
pin diameter 21.997-22.009mm
pin to piston clearance -.005 - +.001mm
pin to rod clearance .005 - .011mm
pin installing temp 70-80*C
the cylinder out of round and wear specs are the same for the 3.0 and 3.2
hope that helps!
3d914
Is there a prescribed location to measure the SHO piston diameter? I'm guessing just after the oil ring groove.
