WhiteSHO91
- Joined
- Feb 9, 2015
- Messages
- 26
- Reaction score
- 5
my a/c in my 91 sho does not work, so in the summer I never use the climate control, I just keep it off. but now that were starting to have cooler mornings, im starting to (attempt to) use it. The problem is it will only blow air on the windshield. no matter which zone I select, it blows on defrost. I replaced the climate control unit with a hard button unit out of a 95 Taurus and it didn't change anything.
I had to replace my blend door actuator last winter and if pulling the dash is required to fix this issue, I want to get it done before I really need it. Any place I should start? When I select different zones I don't hear any hissing noises so I wouldn't suspect a vacuum leak.
