802SHO 2010 Build
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Got some pics today of the Closed Deck conversion and Carrillo Forged pistons. No powder coat pics, I guess it had to be sent back for a redo. Happy to see it coming along. Hopefully I can hit the track by September/October at the latest. Heads need to be assembled and timing set. 77074A35 0CFD 4592 A956 65541E4E45840F060F69 A304 40D8 BDF0 69B8CBEE09ADB8D399AC 180B 4678 9BA0 2C91ACEE194019ED8AB9 568F 45CB 9DC1 3EFD72592CA4FF903D36 25E0 4F2C 9CA0 23F5B6FE1EFC
fordfanstan
CA
Is the block finish decked in those pics? What’s the RA finish? MLS gaskets?
802SHO
I am not 100% sure. I know one side looks better than the other in the pic. I actually learned that he did not end up using Carrillo pistons, they were on back order so he went with Manley Extreme Duty pistons 594910CE-6 with HD pins. He forgot to mention that. I spoke with him earlier today and this is the run down for the motor in his words while driving lol.
“Manley h beam rod with arp2000, Manley pistons, polished crankshaft with wpc, wpc pins, boundary oil pump with new oem housing, oem water pump and timing chains, king xp rods and mains, livernois/arp main and head studs witch are arp8740 bolts,cnc heads,supertech valve springs,ported intake, and front cover valve covers and intake powder coated. Sorry I'm driving so this has been extremely hard to write”. “Also all machine work needed bore,hone,Resurface block ,heads,cnc,5 angle valve job,align hone mains,balance assembly and polish crankshaft and closed deck conversion”.
At the end of the day I’ll have a full build sheet and engine blueprint I think is what he said. Pistons are .02 over and going for 11:1 compression.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Damn so only 900hp capable not 1000hp...
802SHO
Welcome to the Thunder Dome!!! Mad Max Theme starting to come alive! Actually did some stuff to the car today. Going to need to smooth and straighten out my cuts but looking decent. Swapped the entire design of the diffuser over to 3/8 abs. Doing a spoiler extension I guess I would call it, need to put it on my garage counter top and heat and bend up the end of it a little. Hope everyone had a good Memorial Day! 465A7D4E 32B4 4257 B4BE 4E735476313EB12FCD4E A560 4069 BCDD B2F029AF735477A21D70 B4C8 4787 9A33 4777D9F28984B9E61819 5230 4839 9F7D A149B43BDCAA3126AD48 39C0 4605 9306 52089702FD7FA745A152 3E4F 421B A809 7BD09EA4DC00F699F2A3 939B 46D8 B74F 0CFC9469E6B863B8CDDA 3357 466D 8103 ED0E0C9256A69901994C A680 4EA7 BB83 89E0B8BBF81F980E02D1 33F7 43B9 8FCB E424E683287CC2B7A7A1 027B 453B 9E91 26F5408AA79D084EDF4D 9610 410B B072 59BDF21F6B22
Jordan_R
Missouri
I love it man! Definitely love the direction you are taking your SHO! Definitely something I would never be able to pull off so glad you are knocking it out the park!
Bluezone
Ont, Canada
Welcome to the Thunder Dome!!! Mad Max Theme starting to come alive! Actually did some stuff to the car today. Going to need to smooth and straighten out my cuts but looking decent. Swapped the entire design of the diffuser over to 3/8 abs. Doing a spoiler extension I guess I would call it, need to put it on my garage counter top and heat and bend up the end of it a little. Hope everyone had a good Memorial Day! View attachment 18899View attachment 18900View attachment 18901View attachment 18902View attachment 18903View attachment 18904View attachment 18905View attachment 18906View attachment 18907View attachment 18908View attachment 18909View attachment 18910
The diffuser on the back looks great. I got a couple questions for you though. Are the strakes parallel to the ground and is the upper panel about three to six degrees? I was looking at the pictures and that's roughly what it looks like to me. Was this intentional, because that's roughly what they suggest for building a functional rear diffuser.
Are you are you hide'n some hidden skillz?
802SHO
Actually not at all, I didn’t think about that for a second. All I was thinking about was it’s got to be about 12lbs. If it’s also functional then that’s pretty damn cool then! Damn, my guess work is my best work!
