8 hours later...
CademiaX
What's an SHO?
Utah
The new springs, struts and mounts have been installed!! WOO!
[eibach springs, monroe sensa-track struts, monroe strut mounts, monroe bellows]
Now for the bad news. :(
There is a broken end link on the rear right.
Good news.
New ones on the way from shosource! :)
Id have to say some bigger sway bars are in order now, with a body stiffening kit, new h-brace, and a few other goodies :)
:omgsho:
and a big thanks to Jared and Lou for all the help, they aren't members but they deserve a thanks!
Green Sho
Agawam, MA
Any pics? I am going with this combo on my car very soon and I was wondering what it would look like before the springs settle. Did you cut any coils or anything?
SuperHO
Mental Patient
St. Joe, MI
it'll bring the car down noticeably, but not so much as to make it unusable. gives it a decent stance.
CademiaX
What's an SHO?
Utah
Ill get you some pics tonight after work, the first night it sat really high but then I drove it home and everything settled into place, not broken in yet, obviously. I have slicers and standard size tires, look on the passenger side rear door by the strike plate to get the size, and the tires sit about 1 1/2 to 2 in from the wheel well lip. I assume they will settle a bit more in about 500-1000 miles. Then I will be rolling the rear well lips so I can do some wider wheel/tire combos, will look sweet when I'm done :)
It is noticeably lower then stock for sure, mine was sagging in the back, so it only dropped slightly but still noticeable. All around it looks a lot better, everyone will definately notice that its not a standard Taurus, but then again some people are stupid :)
and no, I didnt cut my springs, I wouldn't do that on sensa-tracks anyways.
boat
Likes blue ones
Tallahassee, FL
I have the similar setup and I like it. Going down the road it gives a nice stock feel, but going into corners at higher speeds it gets progressively stiffer, feels nice and solid. It started with the monroe quickstruts, with stock springs. Now it is the same quickstruts, just with the springs changed to eibachs. I have had mine on for almost 2000 miles.
bmytych
