60k tools!
91 Plus
Well-Known Member
Monroe,Michigan
Anyone here have to tools to do the 60k? If you are close wondering If i could borrow them,if not anyone got them for a fair price? I really would like to get my valve adjustment dont since i am almost at 140k and never been done that i know of!
SHOtimer
#2910
Santa Clarita, Ca
They are not that expensive to buy and own for yourself. I am getting ready to purchase the two tools for myself, for my first 60k in Dec. They are about 20 bucks each, you can order them directly from the company that makes them OTC. If you run a search you can find their phone # and the part #s for the two tools, hope this helps
Doug
Lurch
Knoxville, TN
I very recently received (Monday) my 1991 SHO with 75k miles on it. I got it from the used lot of a new car dealership, don't know the previous owner, is there any way I can tell if the 60k has been performed, and if it hasn't, what all does a 60k entail?
New SHO guy
shojuan
sunny San Juan Bautista,
Well for starters you can pull a front spark plug (clean the plug well first and make sure to tighten with a torque wrench when you put it back!) and see if the spark plug looks like it has 75,000 miles on it or 15,000 miles. The next thing to check is the condition of the accessory belts. Do they look almost brand new or do they look a bit old? Also you can remove the end crossover tube on the intake manifold to see if things look really coked up in there or if there's just a light black coating.
Chances are your car didn't get a 60K. It involves
front end: replace timing belt, accessory belts, crank position sensor (CPS), front crank seal, water pump. The last three are preventative replacements if they aren't failing. If in good shape and money is tight you can try putting those off till 120,000 miles. If you have some extra money you can replace them for peace of mind.
top end: adjust valve clearances, inspect/replace shims as necessary (or replace 'em all for peace of mind), clean sludge and coke out of intake manifold and lower intake runners (in cylinder head. Exposed when the intake manifold is off). Replace spark plugs (replace wires at 120K or if the wires are fouled). Replace spark plug well seals, intake gaskets and valve cover gasket as needed (if damaged or leaking. If not for peace of mind if you desire). Clean EGR nostrils if you have EGR and they are plugged. Clean IAB valve while off the car if you have cleanable version.
As needed or when their time is up (hoses): Replace thermostat, cooling system hoses, temperature gauge sender, ECT sender.
The big things are replacing the timing belt, spark plugs, and adjusting the valves/inspecting and replacing the shims. The other items are important too but the parts add up. It sounds intimidating and the parts can add up to quite a bit of money and it can take a bit of time your first time. However after doing this once at the beginning of September, I actually look forward to doing my next 60K at about 210,000 miles! Good oportunity to see how well things hold up over all the miles that I am finally enjoying.
About that last statement, my SHO is much more enjoyable to drive since I did the 60K. A SHO without the 60K can be robbed of quite a bit of power.
Rick
<small>[ October 25, 2002, 02:53 AM: Message edited by: shojuan ]</small>
