60k Maintenance Kit
Mike Kopstain
Arlington Heights, IL
It all depends on what you consider a 60k. :)
If all you are looking for is the shims and tools, then www.shoshop.com. If you have the tools and are looking just for shims, then www.shonutperformance.com.
If you are doing what most here consider a full 60k, I.E. Water pump, crank sensor, crank seal, CPS, timing belt, valve cover gaskets, spark plugs, spark plug wires, etc, then www.midwestsho.com.
We offer a maintenance kit which includes:
- Water Pump
- Timing Belt
- Spark Plug Wires
- Valve Cover Gaskets
- Intake Gaskets
- Crank Sensor
- Crank Seal
- Accessory Belts
- Spark Plugs
$529.99
Josh at SHO NUT Performance offers:
- V6 Tappet Compressor Tool T89P-6500-A 34.04
- V6 Tappet Holder Tool T89P-6500-B 26.48
- V6 56 shim rental new & used rental kit 65.00
Dual Plenum92
Walkerton, IN
Thanks
yeah i was looking for a whole kit but i do have the tools and i will probably go with midwest sho. so thanks a lot for the information.
DP92
