3 probs
raff18
frosty95mtx
ontario canada
hi all thanks for any input u might have
#1 my check oil light stays on even when my oil is right up maybe 2 out of 3 starts it will stay on the other it will go away hummmmm i looked at the wires to it and they seem fine so im lost
#2 while driving (mtx) say at 40mph or so and i goto shift or come to a stop the rpms will dip to 550 the oil light blink for a split sec and headlights will dim then the rpms go back to 900 and stay there like normal but wont do it if im in 4 gear and press in the clutch only any thing lower than 4 gear
#3 my speedo has a life of its own sometimes will jump all over the place 40kph to 80 to 50 to 100 and just keep jumping but doesnt do it all the time and then will be normal again for a while and then throws a fit again hahaha
well thats it for now lol :swing:
heres a little more info the rod bearings were just done less then a 1000kms
cam sensor was done at the same time
zblackbeast
SHOtarded
Omaha, NE
1st one is your sensor most likely. I would replace it
2nd one does sound like a cam sensor (i would still do your rod bearings)
3rd one is your speedo cable.. Im not sure which one, but its one of them! :D
itwonder
VA
1. Order new oil level sensor from Ford deal ~$55
2. Do the idle reset procedure. Disconnect battery, headlight switch on. Wait 5 minutes. Headlights off. Re-connect battery. Start engine and immediately turn on high beam headlights and A/C full blast. Computer will reset idle. If it continues, TB and IAC may need cleaning.
3. Check speedo cables and lubricate.
SHObill
'The Collector'
Rochester MI-48307Detroit
does your climate control have a 'life of its own' too?
check the output of the Alt! May be too high or spike & will cause alll kinds of issues.
raff18
frosty95mtx
ontario canada
got to love seafoam it fixed 2 out of three probs guess there was alot of carbon in my engine now just need to get my speedo prob fixed
