3 Bar Map Sensor
SilverSH0
Is it worth having for everyday use? What are the benefits and incentives you'll receive.
You can push more boost if you are tuned. With the stock 2 bar sensor it will only detect up to 2 bar absolute pressure (so 14.5 psi boost) and that will limit how much boost it can read. Swap it out and it will be able to read up to 3 bar absolute pressure (29 psi boost) so a tuner can have the car push more boost.
By itself it doesn't really do anything to my knowledge. Really, at a minimum you have to have a tuner or someone adjust for the swap so the computer properly reads the new range. If you do end up getting a tuner and 3 bar sensor I recommend buying the sensor from RockAuto or Amazon (vs various performance shops). On RockAuto I think they're $40 (Motorcraft CX2231) while the speed shops are $70+.
gimpy
Pennsylvania
I use my SHO as DD and would suggest adding the 3bar MAP to what you currently have.
Seeing that you already have a tune for it, you are (in a sense) restricting your car.
A 3bar will let it produce more peak boost and also allow it to be more consistent.
RainsFather
2015 SHO PP
OKC
Make sure you got the 3bar sensor. I will have to do some searching but when looking to purchase mine I found out that CX2231 is the form factor (or some such BS) and the actual part number is AA5Z-9F479-B for 3bar and AA5Z-9F479-A for 2bar.
