3.2 swap to 90 Sho
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
Alright so ive decided to do a 3.2 swap into my car and I was wondering if there is anything else that i need to do. I do know there is some modifying to the front head on the 3.2 to get that lift bracket to fit in place. drlling and tapping to do on a few bosses.
I do know that the accessories on the 3.0 will transfer over.. which is rather nice cuz they've all been replaced.:nut:
3.0 intake can be used.
Uhh.. im in a bit of a brainfart right now... so Im pretty sure theres much more to it right now. Im just posting this just to see what everyone else thinks and maybe give me a little bit of guidance.
Cheers
Green Sho
Agawam, MA
if you do a search on it...there's plenty of info..including whole lists of exactly what you need
Paul
Guest
Hilltop
The biggest hurtle is drilling & tappin the head for the coil bracket. I believe every thing else will bolt on. I know the motor mount brackets need to be swapped and there are minor differences with the intake. If the engine controls on the old motor were working well (idle,secondairies,ect..) I sitck with the 3.0 intake. Of course if the engine is out this is the best time to do a 60k tune-up, Plug well seals, ect... I'd stay away from the rear seal if it's not leaking.
