SuperHO
Mental Patient
Yup...I done broked it right good. Anyway, upon investigation I saw a threaded hole approximately 1 inch away from the tensioner hole and I'm wondering if I can use that instead of drilling out the stud and tapping a new hole. I've always wound up frocking the hole up whenever I try drilling something out, and considering this is the only block I got, I can't afford to screw it up.
Also, since It's a 3.2 block, would it be possible to use an ATX tensioner, or does that use Tue same hole as the MTX one?
Thanks!
Thanks!
