OK, also finished up the design mods on the engine cradle. Bought the basic design on line from Russ Green. Needed to simplify some for V6 use and the fact that I wanted the clutch & tranny installed when I test the engine.
The cradle I've redesigned will be moved into position and connected up before the engine bar is installed or removed. The cradle supports the engine & tranny while the engine bar is removed and the cradle is fastened up. The engine bar installs from the front of the engine.
The cradle is also designed to fit with my ATV lift. Of course the radiator supports are removed for engine install.
