3.2 and 3.0 throttle cables...differences or no?
Blue-By-U
CT
While searching for the answer I've read a few responses as to why they might be different (TB bracket, length) but didn't actually come across a concrete answer.
Are they the same cable? I want to swap mine with the one from my 94 ATX parts car.
TIA
SHOguy 92
Duluth, MN
My guess is they are diffrent seeing as the engine sits farther forward in the ATX. Which to me would mean more distance between the pedal and the throttle body. But I have no proof of this just my guess. Also is your 3.2 good my guess is no or a swap would be in order, well good luck. Also if your cable is stretched why don't yoou try and put some sort of spacers between the pedal and the end of the line to take away slack, then you can adjust spacer sizing if its off.
<small>[ January 23, 2004, 01:57 AM: Message edited by: SHOguy11 ]</small>
