rigol2000
Need a 60k
I've been having a squeeking noise from my access belt area that I thought was the belt itself. After some time went by, the squeeking (that increased with the RPMs) got louder and sounds more mechanical than just a belt. To save time, I brought it to a shop and paid for a diagnostic to find which part it may be so I could maybe replace it. They came up with the tensioner pulley assembly. They said they would only be able to get it from Ford and it would be $230 for the part. I tried looking around the net,but could not come up with anything.
First question; is this part that rare?
Second question (forgive me if it's stupid, I'm not too mechanical) can the pully's squeeking be a lubrication problem? It's a noticable low squeek at idle, then becomes louder and faster with throttle. "squeek squeek squeek..." The other day I drove through a pretty big puddle and splashed alot of water. The squeeking stopped for about 30 seconds.
Thanks,
Chris
Thanks,
Chris
. Even though I was able to spin the pulleys freely without squeaking, that doesn’t mean they wouldn’t squeak under the pressure of the belt. Right? Really, it’s coming from the rear, so it could be the power steering pump, water pump or the tensioner. I wonder if a little **** could quiet the squeaker up? (Always looking for an easy fix)
